Philco 90 question
There were electrolytic caps there. Likely they have been replaced with either aluminum or if you lucky with polyester tubular caps.
Philco 90 question - by SteveG - 08-14-2015, 06:02 PM
RE: Philco 90 question - by KCMike - 08-14-2015, 06:39 PM
RE: Philco 90 question - by SteveG - 08-14-2015, 06:44 PM
RE: Philco 90 question - by SteveG - 08-14-2015, 06:57 PM
RE: Philco 90 question - by Eliot Ness - 08-14-2015, 07:04 PM
RE: Philco 90 question - by morzh - 08-14-2015, 07:04 PM
RE: Philco 90 question - by Nathan Slingerland - 08-14-2015, 07:15 PM
RE: Philco 90 question - by SteveG - 08-14-2015, 07:25 PM
RE: Philco 90 question - by Eliot Ness - 08-14-2015, 08:02 PM
There are currently 5478 online users. [Complete List]
» 1 Member(s) | 5477 Guest(s)
