1937 Philco 37-620 chairside and 1936 640 tombstone
Geez, those shaby chic nuts go a bit far, sometimes you wonder if people engage the grey matter before doing stuff like checking to see if the staples are too long etc.
Re: 1937 Philco 37-620 chairside and 1936 640 tombstone - by 49Stude63 - 02-23-2009, 11:24 PM
Eico 232 VTVM Schematic
There are currently 9870 online users. [Complete List]
» 1 Member(s) | 9869 Guest(s)
