40-190 What is this?
I just realized the cardboard covering was missing off your antenna. There was some sort of a metal mesh grid in there originally, which I'm assuming was part of the antenna. This might be intended as a sub for said mesh grid.
40-190 What is this? - by Edisla - 07-19-2015, 12:47 PM
RE: 40-190 What is this? - by morzh - 07-19-2015, 03:44 PM
RE: 40-190 What is this? - by Arran - 07-19-2015, 05:00 PM
RE: 40-190 What is this? - by DeckApe - 07-20-2015, 10:43 PM
RE: 40-190 What is this? - by Joeztech - 08-01-2015, 03:41 PM
RE: 40-190 What is this? - by Edisla - 08-02-2015, 01:01 PM
RE: 40-190 What is this? - by Edisla - 08-02-2015, 01:03 PM
RE: 40-190 What is this? - by DeckApe - 08-16-2015, 10:10 PM
RE: 40-190 What is this? - by Edisla - 10-07-2015, 09:36 PM
RE: 40-190 What is this? - by Edisla - 10-07-2015, 09:37 PM
RE: 40-190 What is this? - by Ron Ramirez - 10-07-2015, 09:43 PM
