Philco 60B Restoration
Today I did some wood filling along the bottom trim piece. I filled the nail holes, some depressions, and spaces between the front and side pieces. I did a quick sanding on it and applied some more wood filler. I'll let it set overnight, then sand some more tomorrow.
I'm using Famowood wood filler, walnut color. Fred Taylor told me he uses the stuff. That's good enough for me!
[Image: http://i1060.photobucket.com/albums/t458...ubfrzv.jpg]
[Image: http://i1060.photobucket.com/albums/t458...xnmp3h.jpg]
[Image: http://i1060.photobucket.com/albums/t458...ezhhmo.jpg]
[Image: http://i1060.photobucket.com/albums/t458...pvyntg.jpg]
[Image: http://i1060.photobucket.com/albums/t458...gp56g7.jpg]
Crist
Philco 60B Restoration - by Crist Rigotti - 06-23-2015, 06:51 PM
RE: Philco 60B Restoration - by jerryhawthorne - 06-23-2015, 07:11 PM
RE: Philco 60B Restoration - by Ron Ramirez - 06-23-2015, 08:16 PM
RE: Philco 60B Restoration - by Fred Taylor - 06-23-2015, 10:38 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-23-2015, 10:51 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-25-2015, 11:09 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 03:58 PM
RE: Philco 60B Restoration - by morzh - 06-27-2015, 04:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 07:25 PM
RE: Philco 60B Restoration - by Fred Taylor - 06-27-2015, 07:55 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 08:04 PM
RE: Philco 60B Restoration - by Eliot Ness - 06-27-2015, 10:48 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-28-2015, 12:33 AM
RE: Philco 60B Restoration - by Crist Rigotti - 06-29-2015, 11:34 PM
RE: Philco 60B Restoration - by Kestas - 06-30-2015, 01:33 PM
RE: Philco 60B Restoration - by morzh - 06-30-2015, 02:00 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-30-2015, 04:07 PM
RE: Philco 60B Restoration - by morzh - 06-30-2015, 04:22 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-30-2015, 10:38 PM
RE: Philco 60B Restoration - by Crist Rigotti - 07-05-2015, 12:16 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-15-2015, 12:34 PM
RE: Philco 60B Restoration - by OldRestorer - 08-15-2015, 07:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-17-2015, 01:03 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-18-2015, 10:32 AM
RE: Philco 60B Restoration - by OldRestorer - 08-18-2015, 03:30 PM
RE: Philco 60B Restoration - by Ron Ramirez - 08-18-2015, 04:27 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-18-2015, 10:24 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-19-2015, 01:36 PM
RE: Philco 60B Restoration - by Ron Ramirez - 08-19-2015, 08:22 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-27-2015, 11:32 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-28-2015, 03:37 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-28-2015, 09:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-28-2015, 10:09 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 05:23 PM
RE: Philco 60B Restoration - by jerryhawthorne - 08-30-2015, 05:49 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 07:03 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-30-2015, 07:18 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 08:50 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-31-2015, 08:58 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-31-2015, 11:27 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 10:32 PM
RE: Philco 60B Restoration - by Crist Rigotti - 09-01-2015, 04:47 PM
RE: Philco 60B Restoration - by jerryhawthorne - 09-01-2015, 05:04 PM
RE: Philco 60B Restoration - by Eliot Ness - 09-01-2015, 06:04 PM
RE: Philco 60B Restoration - by KCMike - 09-01-2015, 06:27 PM
RE: Philco 60B Restoration - by Fred Taylor - 09-01-2015, 08:11 PM
RE: Philco 60B Restoration - by Crist Rigotti - 09-04-2015, 02:28 PM
RE: Philco 60B Restoration - by OldRestorer - 09-04-2015, 02:48 PM
RE: Philco 60B Restoration - by Fred Taylor - 09-05-2015, 07:31 PM
RE: Philco 60B Restoration - by PhilcoJohn - 09-06-2015, 06:25 AM
Users browsing this thread: 15 Guest(s)
There are currently 10194 online users. [Complete List]
» 1 Member(s) | 10193 Guest(s)
