Mid-century portable 53-658
hey bob
battery is easy to make
make sure you clean  battery / plug   switch really good
tight space to replace caps but worth it
if you can`t find or make handle
http://www.brettunsvillage.com/trunks/ho...andles.htm
sam
Mid-century portable 53-658 - by klondike98 - 08-13-2015, 10:18 PM
RE: Mid-century portable 53-658 - by sam - 08-14-2015, 03:28 AM
RE: Mid-century portable 53-658 - by Radioroslyn - 08-14-2015, 06:08 AM
RE: Mid-century portable 53-658 - by Arran - 09-01-2015, 03:37 AM
RE: Mid-century portable 53-658 - by codefox1 - 08-14-2015, 09:25 AM
RE: Mid-century portable 53-658 - by klondike98 - 08-14-2015, 12:21 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-14-2015, 03:30 PM
RE: Mid-century portable 53-658 - by Raleigh - 08-16-2015, 09:03 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-16-2015, 11:17 PM
RE: Mid-century portable 53-658 - by Eliot Ness - 08-17-2015, 06:41 AM
RE: Mid-century portable 53-658 - by klondike98 - 08-17-2015, 11:19 AM
RE: Mid-century portable 53-658 - by sam - 08-17-2015, 12:46 PM
RE: Mid-century portable 53-658 - by codefox1 - 08-17-2015, 05:56 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-17-2015, 07:03 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-18-2015, 01:15 PM
There are currently 6975 online users. [Complete List]
» 2 Member(s) | 6973 Guest(s)
