The Great Crosley WLW Radio
Sam
Photos please!!!
Would you mind editing your first post and removing the bit about the McMurdo Silver, and start a new, separate thread on that radio? Since these are two quite different radios, it would help promote discussion on both without having things become confusing. Thanks.
The Great Crosley WLW Radio - by Sam samuelian - 08-18-2015, 12:55 AM
RE: The Great Crosley WLW Radio - by Jayce - 08-18-2015, 01:32 AM
RE: The Great Crosley WLW Radio - by Ron Ramirez - 08-18-2015, 06:17 AM
RE: The Great Crosley WLW Radio - by Jayce - 08-18-2015, 12:42 PM
RE: The Great Crosley WLW Radio - by KCMike - 08-18-2015, 03:45 PM
RE: The Great Crosley WLW Radio - by tab10672 - 08-18-2015, 06:27 PM
RE: The Great Crosley WLW Radio - by chucka - 08-19-2015, 04:41 PM
RE: The Great Crosley WLW Radio - by PhilcoJohn - 08-20-2015, 06:28 PM
RE: The Great Crosley WLW Radio - by TA Forbes - 08-22-2015, 09:36 AM
RE: The Great Crosley WLW Radio - by Fred Taylor - 08-22-2015, 07:56 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2903 online users. [Complete List]
» 3 Member(s) | 2900 Guest(s)
