Capacitator polarity something new I had not heard of
Has anyone else seen this video. I didn't know that (non electrolytic caps) foil caps had a polarity to them. It's based on the outside foil lead vs the inside lead of the roll. If they are installed with the outside lead to the low impedance side of the circuit its cut down the noise sensitivity of the cap. .
https://www.youtube.com/watch?v=BnR_DLd1PDI
Capacitator polarity something new I had not heard of - by OZ4 - 08-18-2015, 02:43 PM
There are currently 4530 online users. [Complete List]
» 2 Member(s) | 4528 Guest(s)
