Poor poor little National HRO Senior L76
#61
Now that sounds cool
Hope he returns message
Sam
OT RCA 6T71 1950 TV - by Radioroslyn - 06-13-2015, 10:19 PM
RE: Poor poor little National HRO Senior L76 - by sam - 08-20-2015, 10:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
