help with an old repair - 40-201 chassis
#34
clearly it's not clear to me. Could it be that I am simply overwhelmed or losing some of my marbles in the 40's? Not so fun to ponder possibly, but thanks for the clarity -
rereading the schematic I see that the "location of 7C6 tube in the 40-195" is the same location as the 40-201, hence the understanding now that I am no further "better" at this than 3 hours ago when I started this project!!
Don't fear! I cannot let all this advice and opinion go to waste - I will carry on...one mistake at a time!!
RE: help with an old repair - 40-201 chassis - by David Van Wickler - 08-21-2015, 08:06 AM
Users browsing this thread: 21 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8969 online users. [Complete List]
» 3 Member(s) | 8966 Guest(s)
