37-10 plate voltages 100 vdc high
Outputs  2  (6f6g), 6k7g (if); 6k7g (rf), voltages all 100 volts high.
Possible cause and or possible fix, and or any help i can get.
Thanks as always to those more wise than me.
TT
37-10 plate voltages 100 vdc high - by ttmiller - 08-21-2015, 04:12 PM
RE: 37-10 plate voltages 100 vdc high - by Arran - 09-18-2015, 05:24 AM
There are currently 5761 online users. [Complete List]
» 1 Member(s) | 5760 Guest(s)
