  • 1 Vote(s) - 3 Average
Phono cartridge retro fit?
It's probably similar to the cartridge in my M-22 but I have yet to tear into that so I'm not sure. Both are tilt cartridges though. You can try a Pfansteihl 226 or 228 which are stereo. Some new cartridges include the clips to attach the wires to the cartridge. You can solder the clips to the wires and then attach the clips to the cartridge. Never solder wires directly to the cartridge's pins! I agree you will have to get creative in mounting the new cartridge but I suppose that's part of the fun! The new cartridge will have a flip stylus which will render the button on top of the tone arm useless. You might contact Gary at the Voice of Music website and see if he can tell you which replacement would work best. He sells them all!
Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 03:10 PM
RE: Phono cartridge retro fit? - by Squire - 08-18-2015, 05:51 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 09:11 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 01:44 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-21-2015, 09:18 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 11:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-22-2015, 07:30 AM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 03:41 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-24-2015, 06:28 PM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 07:16 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-06-2015, 08:13 AM
RE: Phono cartridge retro fit? - by Squire - 09-07-2015, 02:16 AM
RE: Phono cartridge retro fit? - by ODPILOT - 09-10-2015, 08:51 PM
RE: Phono cartridge retro fit? - by Squire - 09-11-2015, 08:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-19-2015, 12:00 PM
RE: Phono cartridge retro fit? - by Squire - 09-19-2015, 07:55 PM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 02:20 AM
RE: Phono cartridge retro fit? - by sam - 10-02-2015, 03:38 AM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 03:25 PM
RE: Phono cartridge retro fit? - by ODPILOT - 10-10-2015, 02:54 PM
RE: Phono cartridge retro fit? - by Squire - 10-11-2015, 11:47 AM
There are currently 5909 online users. [Complete List]
» 2 Member(s) | 5907 Guest(s)
