Loose tuning capacitor on model 70
Well, you can operate it, but you may experience unexplainable static or intermittent loss of reception.
More causes of that, plus repairs you should do to any Model 20, 50, 70 or 90 tuning condenser are found here:
http://www.philcoradio.com/tech/tuner.htm
Re: Loose tuning capacitor on model 70 - by Ron Ramirez - 03-29-2009, 01:43 PM
