My Museum Quality Philco Console 37-690 Radio
BIN or BO works worse than auction if one wants higher than usual price. On average. The risk is obviously higher with auctions.
RE: My Museum Quality Philco Console 38-690 Radio - by morzh - 08-22-2015, 09:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
