New here! How to post pictures?
There's also a tab underneath the message posting box that says "upload attachment." Hit "Post a Reply" and you will see it. You can upload the pictures directly to the page that way, if you don't have them already uploaded to a website.
Re: New here! How to post pictures? - by exray - 02-26-2009, 10:57 PM
Re: New here! How to post pictures? - by mikehorning - 02-27-2009, 12:44 AM
Re: New here! How to post pictures? - by exray - 02-27-2009, 07:54 AM
