My Museum Quality Philco Console 37-690 Radio
Unfortunately that is a common problem, ARC did not seem to reinvent itself in time and format to swim upstream as a hobby publication. Not to get off the thread but............mnay were dissapointed.
RE: My Museum Quality Philco Console 38-690 Radio - by Paul Philco322 - 08-23-2015, 07:38 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
