What model is this?
28L or 32L, or 38L. The year of 1935.
Not exactly rare, not too common either.,
What model is this? - by SteveG - 08-24-2015, 05:20 PM
RE: What model is this? - by morzh - 08-24-2015, 05:48 PM
RE: What model is this? - by Ron Ramirez - 08-24-2015, 08:15 PM
RE: What model is this? - by SteveG - 08-24-2015, 09:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
