  • 1 Vote(s) - 3 Average
Phono cartridge retro fit?
Yes, I think the M22, M24, M24 A - all used the same exact tone arm, cartridge and stylus. I did talk to the people at V/M Enthusiasts, and he recommended for a replacement the Pfansteihl P51-3, but it only will play 78's and 45's (not 33 1/3). So he also recommended the EV 5632 HLF, part # DS73 as a replacement as well, since it has a flip needle and can play all speeds. I ordered one - let's see if I can make it fit into the old tone arm. Before I install it, I will try to rebuild the old cartridge as well - but it seems to be a very tedious task and am doubtful that I will be able to make it as good as new.
Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 03:10 PM
RE: Phono cartridge retro fit? - by Squire - 08-18-2015, 05:51 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 09:11 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 01:44 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-21-2015, 09:18 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 11:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-22-2015, 07:30 AM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 03:41 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-24-2015, 06:28 PM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 07:16 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-06-2015, 08:13 AM
RE: Phono cartridge retro fit? - by Squire - 09-07-2015, 02:16 AM
RE: Phono cartridge retro fit? - by ODPILOT - 09-10-2015, 08:51 PM
RE: Phono cartridge retro fit? - by Squire - 09-11-2015, 08:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-19-2015, 12:00 PM
RE: Phono cartridge retro fit? - by Squire - 09-19-2015, 07:55 PM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 02:20 AM
RE: Phono cartridge retro fit? - by sam - 10-02-2015, 03:38 AM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 03:25 PM
RE: Phono cartridge retro fit? - by ODPILOT - 10-10-2015, 02:54 PM
RE: Phono cartridge retro fit? - by Squire - 10-11-2015, 11:47 AM
There are currently 5190 online users. [Complete List]
» 2 Member(s) | 5188 Guest(s)
