My Museum Quality Philco Console 37-690 Radio
Steve I have often wondered the same thing. Where does he get all of those consoles?
RE: My Museum Quality Philco Console 38-690 Radio - by PhilcoJohn - 08-26-2015, 08:43 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
