Philco 70 Escutcheon
(08-26-2015, 06:51 PM)Eliot Ness Wrote:  Some 70 and 90 escutcheons were brass and some were Bakelite.  I believe the earlier versions had brass and they later switched to Bakelite.
Thanks for the reply. This 70 is an early model with a single 47 output .
                                                           Henry
Philco 70 Escutcheon - by radiohenry - 08-26-2015, 06:38 PM
RE: Philco 70 Escutcheon - by Eliot Ness - 08-26-2015, 06:51 PM
RE: Philco 70 Escutcheon - by radiohenry - 08-26-2015, 06:57 PM
RE: Philco 70 Escutcheon - by tab10672 - 08-26-2015, 07:12 PM
RE: Philco 70 Escutcheon - by Eliot Ness - 08-26-2015, 07:36 PM
RE: Philco 70 Escutcheon - by radiohenry - 08-26-2015, 07:58 PM
RE: Philco 70 Escutcheon - by Radioroslyn - 08-28-2015, 05:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
