Philco 70 Escutcheon
I have an early 70 with bakelite escutcheon and a late model (new chassis without 24a's) with brass escutcheon. I know the one with bakelite has never been touched, the other one, who knows?
Philco 70 Escutcheon - by radiohenry - 08-26-2015, 06:38 PM
RE: Philco 70 Escutcheon - by Eliot Ness - 08-26-2015, 06:51 PM
RE: Philco 70 Escutcheon - by radiohenry - 08-26-2015, 06:57 PM
RE: Philco 70 Escutcheon - by tab10672 - 08-26-2015, 07:12 PM
RE: Philco 70 Escutcheon - by Eliot Ness - 08-26-2015, 07:36 PM
RE: Philco 70 Escutcheon - by radiohenry - 08-26-2015, 07:58 PM
RE: Philco 70 Escutcheon - by Radioroslyn - 08-28-2015, 05:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7186 online users. [Complete List]
» 1 Member(s) | 7185 Guest(s)
