A little info 16B Cathedral,Please
Some consider it arguably the best tabletop by Philco. I got one from Ron
A little info 16B Cathedral,Please - by doug-5er - 08-29-2015, 08:32 PM
RE: A little info 16B Cathedral,Please - by morzh - 08-29-2015, 10:34 PM
RE: A little info 16B Cathedral,Please - by morzh - 08-31-2015, 03:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
