philco 37-10 electrolytic question
thank you for reply,i was reading the cap symbol backward, i thought the side with smaller line (upside down t ) was the ground. also should i recap all bakelite blocks? thanks for info
philco 37-10 electrolytic question - by Guest - 02-26-2009, 01:23 PM
Re: philco 37-10 electrolytic question - by NV3G - 02-27-2009, 09:50 AM
Re: philco 37-10 electrolytic question - by Guest - 02-28-2009, 12:08 PM
Re: philco 37-10 electrolytic question - by exray - 02-28-2009, 12:40 PM
Re: philco 37-10 electrolytic question - by Guest - 02-28-2009, 03:36 PM
There are currently 10286 online users. [Complete List]
» 3 Member(s) | 10283 Guest(s)
