Philco 46-1209 Code 121
I was able to work on things a bit today. PHEW! Hopefully I will find a better way to do this for next time. I'm sure my blood pressure was a bit high today. I got the potting out of the bakelite block and recapped with the safety caps, and replaced the 33k resistor and 240 pf cap feeding #3 on the 7F8 tube and also replaced a few other resistors that tested out of spec. I did find one suspicious resistor, #57 mixer plate decoupling. The schematics call for a 47K ohm (or a 4.7K depending on model) and I had one that had a green paper wrapper that said 60M, but the color code lead me to believe that it was a 60K. I replaced it with the 47K. After carefully reassembling everything I powered up and everything looked okay. I seem to get more stations now than before but I still have to have the volume turned up considerably. If I hold the antenna while tuning I get A LOT more stations at what seems to be a normal volume, but still not much below 900kHz (buzz @800 kHz) Do I need to do an alignment now?
Philco 46-1209 Code 121 - by heats00 - 07-07-2015, 11:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-08-2015, 12:15 AM
RE: Philco 46-1209 Code 121 - by klondike98 - 07-08-2015, 12:20 AM
RE: Philco 46-1209 Code 121 - by codefox1 - 07-08-2015, 08:56 AM
RE: Philco 46-1209 Code 121 - by Radioroslyn - 07-09-2015, 06:03 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-16-2015, 10:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-06-2015, 02:19 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-07-2015, 12:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-08-2015, 02:30 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-09-2015, 01:46 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-12-2015, 09:04 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-17-2015, 03:55 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-17-2015, 07:33 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-17-2015, 09:14 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-18-2015, 09:27 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-18-2015, 12:18 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-18-2015, 01:02 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 01:00 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 11:13 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 03:23 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 07:22 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-20-2015, 10:56 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-21-2015, 11:33 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-21-2015, 03:49 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-30-2015, 11:21 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 11:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-31-2015, 12:28 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 04:45 PM
RE: Philco 46-1209 Code 121 - by heats00 - 09-03-2015, 11:55 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 09-04-2015, 11:06 AM
There are currently 6095 online users. [Complete List]
» 2 Member(s) | 6093 Guest(s)
