Philco 46-1209 Code 121
[Image: https://lh3.googleusercontent.com/pb7uiK...98-h955-no]
This is the glow I see from the 7X7 tube in the center.  It looks much worse in the camera.  Normal?
I have not checked voltages yet as I ran out of time last night.  I will report back when I can.
Philco 46-1209 Code 121 - by heats00 - 07-07-2015, 11:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-08-2015, 12:15 AM
RE: Philco 46-1209 Code 121 - by klondike98 - 07-08-2015, 12:20 AM
RE: Philco 46-1209 Code 121 - by codefox1 - 07-08-2015, 08:56 AM
RE: Philco 46-1209 Code 121 - by Radioroslyn - 07-09-2015, 06:03 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-16-2015, 10:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-06-2015, 02:19 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-07-2015, 12:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-08-2015, 02:30 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-09-2015, 01:46 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-12-2015, 09:04 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-17-2015, 03:55 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-17-2015, 07:33 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-17-2015, 09:14 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-18-2015, 09:27 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-18-2015, 12:18 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-18-2015, 01:02 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 01:00 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 11:13 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 03:23 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 07:22 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-20-2015, 10:56 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-21-2015, 11:33 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-21-2015, 03:49 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-30-2015, 11:21 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 11:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-31-2015, 12:28 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 04:45 PM
RE: Philco 46-1209 Code 121 - by heats00 - 09-03-2015, 11:55 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 09-04-2015, 11:06 AM
There are currently 5554 online users. [Complete List]
» 2 Member(s) | 5552 Guest(s)
