Philco 60B Restoration
#43
Looks perfect Crist! Very nice job.
jerry
Philco 60B Restoration - by Crist Rigotti - 06-23-2015, 06:51 PM
RE: Philco 60B Restoration - by jerryhawthorne - 06-23-2015, 07:11 PM
RE: Philco 60B Restoration - by Ron Ramirez - 06-23-2015, 08:16 PM
RE: Philco 60B Restoration - by Fred Taylor - 06-23-2015, 10:38 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-23-2015, 10:51 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-25-2015, 11:09 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 03:58 PM
RE: Philco 60B Restoration - by morzh - 06-27-2015, 04:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 07:25 PM
RE: Philco 60B Restoration - by Fred Taylor - 06-27-2015, 07:55 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-27-2015, 08:04 PM
RE: Philco 60B Restoration - by Eliot Ness - 06-27-2015, 10:48 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-28-2015, 12:33 AM
RE: Philco 60B Restoration - by Crist Rigotti - 06-29-2015, 11:34 PM
RE: Philco 60B Restoration - by Kestas - 06-30-2015, 01:33 PM
RE: Philco 60B Restoration - by morzh - 06-30-2015, 02:00 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-30-2015, 04:07 PM
RE: Philco 60B Restoration - by morzh - 06-30-2015, 04:22 PM
RE: Philco 60B Restoration - by Crist Rigotti - 06-30-2015, 10:38 PM
RE: Philco 60B Restoration - by Crist Rigotti - 07-05-2015, 12:16 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-15-2015, 12:34 PM
RE: Philco 60B Restoration - by OldRestorer - 08-15-2015, 07:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-17-2015, 01:03 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-18-2015, 10:32 AM
RE: Philco 60B Restoration - by OldRestorer - 08-18-2015, 03:30 PM
RE: Philco 60B Restoration - by Ron Ramirez - 08-18-2015, 04:27 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-18-2015, 10:24 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-19-2015, 01:36 PM
RE: Philco 60B Restoration - by Ron Ramirez - 08-19-2015, 08:22 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-27-2015, 11:32 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-28-2015, 03:37 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-28-2015, 09:03 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-28-2015, 10:09 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 05:23 PM
RE: Philco 60B Restoration - by jerryhawthorne - 08-30-2015, 05:49 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 07:03 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-30-2015, 07:18 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 08:50 PM
RE: Philco 60B Restoration - by Fred Taylor - 08-31-2015, 08:58 AM
RE: Philco 60B Restoration - by Crist Rigotti - 08-31-2015, 11:27 PM
RE: Philco 60B Restoration - by Crist Rigotti - 08-30-2015, 10:32 PM
RE: Philco 60B Restoration - by Crist Rigotti - 09-01-2015, 04:47 PM
RE: Philco 60B Restoration - by jerryhawthorne - 09-01-2015, 05:04 PM
RE: Philco 60B Restoration - by Eliot Ness - 09-01-2015, 06:04 PM
RE: Philco 60B Restoration - by KCMike - 09-01-2015, 06:27 PM
RE: Philco 60B Restoration - by Fred Taylor - 09-01-2015, 08:11 PM
RE: Philco 60B Restoration - by Crist Rigotti - 09-04-2015, 02:28 PM
RE: Philco 60B Restoration - by OldRestorer - 09-04-2015, 02:48 PM
RE: Philco 60B Restoration - by Fred Taylor - 09-05-2015, 07:31 PM
RE: Philco 60B Restoration - by PhilcoJohn - 09-06-2015, 06:25 AM
