AES power supply kit mods?
Nice looking "battery" box. The brass hardware is a good touch, and the labels look good.
Do you have a vent for air intake (or exhaust, depending on the direction of the fan)? The fan won't do much good without a way to let the air flow through.
John Honeycutt
AES power supply kit mods? - by ccomer1955 - 07-23-2015, 12:49 PM
RE: AES power supply kit mods? - by morzh - 07-23-2015, 02:50 PM
RE: AES power supply kit mods? - by ccomer1955 - 07-23-2015, 06:05 PM
RE: AES power supply kit mods? - by ccomer1955 - 07-30-2015, 10:17 PM
RE: AES power supply kit mods? - by morzh - 07-31-2015, 10:41 AM
RE: AES power supply kit mods? - by ccomer1955 - 07-31-2015, 01:40 PM
RE: AES power supply kit mods? - by morzh - 07-31-2015, 02:30 PM
RE: AES power supply kit mods? - by ccomer1955 - 07-31-2015, 10:02 PM
RE: AES power supply kit mods? - by morzh - 07-31-2015, 10:09 PM
RE: AES power supply kit mods? - by ccomer1955 - 08-01-2015, 03:00 PM
RE: AES power supply kit mods? - by ccomer1955 - 08-02-2015, 02:06 PM
RE: AES power supply kit mods? - by morzh - 08-02-2015, 04:35 PM
RE: AES power supply kit mods? - by Arran - 08-04-2015, 05:56 AM
RE: AES power supply kit mods? - by Raleigh - 09-02-2015, 09:06 PM
RE: AES power supply kit mods? - by ccomer1955 - 09-02-2015, 10:22 PM
RE: AES power supply kit mods? - by Raleigh - 09-03-2015, 06:14 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3233 online users. [Complete List]
» 4 Member(s) | 3229 Guest(s)
AvatarAvatarAvatarAvatar
