Philco 41-285 cabinet scratches
Wet rag and heat (iron)
Should help the fibers expand back out.
Very little water and test in a inconspicious place. sometimes it can turn the finish white.
Kirk
Philco 41-285 cabinet scratches - by ccomer1955 - 09-04-2015, 01:14 PM
RE: Philco 41-285 cabinet scratches - by OldRestorer - 09-04-2015, 02:24 PM
There are currently 10365 online users. [Complete List]
» 3 Member(s) | 10362 Guest(s)
