Radiola 60 w/ 103 Speaker
Thanks Sam, glad it worked out. If I mess up my own radio I don't feel bad, but if I had messed up theirs I wouldn't feel too good about it. The SSTRAN worked as well though the building they are in must be metal framed as the signal gets noisy with distance. Worked great in my house. They may be moving the display so we did not spend time optimizing things.
Radiola 60 w/ 103 Speaker - by klondike98 - 07-18-2015, 05:44 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 12:43 AM
RE: Radiola 60 w/ 103 Speaker - by sam - 09-05-2015, 10:55 AM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 02:17 PM
RE: Radiola 60 w/ 103 Speaker - by Mondial - 09-05-2015, 03:19 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 05:59 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-06-2015, 12:11 PM
RE: Radiola 60 w/ 103 Speaker - by Mondial - 09-06-2015, 02:13 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-06-2015, 02:49 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
