Radiola 60 w/ 103 Speaker
Here are the links to the larger version of the photos (except the last one which is not really in focus).
(edit...larger photos now in original post above.)
The filter can itself has sides that slide together and if you get one side off the rest will come apart easily.  I set the can on the side of the bench and used a hammer to tap one of the sides to slide it off.  It bent the side a little but was easily tapped back in place.
Radiola 60 w/ 103 Speaker - by klondike98 - 07-18-2015, 05:44 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 12:43 AM
RE: Radiola 60 w/ 103 Speaker - by sam - 09-05-2015, 10:55 AM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 02:17 PM
RE: Radiola 60 w/ 103 Speaker - by Mondial - 09-05-2015, 03:19 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-05-2015, 05:59 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-06-2015, 12:11 PM
RE: Radiola 60 w/ 103 Speaker - by Mondial - 09-06-2015, 02:13 PM
RE: Radiola 60 w/ 103 Speaker - by klondike98 - 09-06-2015, 02:49 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 4242 online users. [Complete List]
» 2 Member(s) | 4240 Guest(s)
