SAMS for '29 Models -- Does it Exist?
Thanks, Jim -- I sent you a separate PM...
For anyone reading's reference, I've figured out a dress shoe lace (thin string type) works perfectly as dial string for these old models that take a thicker dial string. Just fyi.
"Ignorance is bliss...'til you have to fix a radio..."
Re: SAMS for '29 Models -- Does it Exist? - by jayoungs - 03-01-2009, 10:14 PM
There are currently 10388 online users. [Complete List]
» 1 Member(s) | 10387 Guest(s)
