Krylon Satin Nickel for chassis painting
Squire;
Yes, that is the original part number that Krylon produced that worked so well. Since today is a holiday, I probably will not hear from Krylon until Tuesday or later. In the meantime, I will continue to look for the original part number.
Joe
RE: Krylon Satin Nickel for chassis painting - by Joeztech - 09-07-2015, 06:25 AM
There are currently 5364 online users. [Complete List]
» 1 Member(s) | 5363 Guest(s)
