37-11 Alignment and Sensitivity issues
Hi Jason,
I'd drop Chuck a note:
http://www.philcorepairbench.com/
Nice projects, you might find that a VF-1 may replace FT-171s.
Terry N3GTE
37-11 Alignment and Sensitivity issues - by N6MKC - 09-07-2015, 01:55 AM
RE: 37-11 Alignment and Sensitivity issues - by Radioroslyn - 09-07-2015, 12:28 PM
There are currently 7165 online users. [Complete List]
» 1 Member(s) | 7164 Guest(s)
