Discussion About McMurdo Silver V vs. VI Radios
Ron, the video is here:
https://www.dropbox.com/s/ncwh7bz19x88oz...t.m4v?dl=0
This radio was completely recapped a long time ago ('50s or '60s) and it's due again (big project), so I haven't been using it.  However, the seller told me it was working on his bench, so I just had to try it when I got it!
There just happened to be a good song by Bette Midler on when I started recording.   Icon_biggrin
RE: Discussion About McMurdo Silver V vs. VI Radios - by palegreenthumb - 09-10-2015, 12:21 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3576 online users. [Complete List]
» 1 Member(s) | 3575 Guest(s)
