aluminum repair
Pitting in itself is not bad. Just needs to be cleaned and provide good electrical connections to sets of plates.
aluminum repair - by Gene_1950 - 09-10-2015, 07:53 PM
RE: aluminum repair - by morzh - 09-10-2015, 08:44 PM
There are currently 4959 online users. [Complete List]
» 1 Member(s) | 4958 Guest(s)
