41-280 Color Scheme
(09-08-2015, 05:08 PM)Edisla Wrote:  Don't care so much for this set of decals I have. The transparent part doesn't appear to hide as well as a set I got from a different seller.
Did you apply decal before your few last coats of clear? If not there is a product called solfast, you can get it at a hobby shop most of the time. Any way you apply this clear liquid with a small modeling paint brush over the decal and it will get rid of the haziness of the decal and the edge that you see. It melts the decal into the surface without distorting the decal . Its widely used for models where the decal has to look like it was painted on getting into crevices and melting into depressions and rivets such as older airplanes and train cars .Use this only of you haven't cleared over the decal when refinishing. It will not hurt the clear coat. Always try to apply decal before your last two coats of clear coat and you would not have this problem.
41-280 finish - by Edisla - 04-26-2015, 01:09 AM
RE: 41-280 Color Scheme - by Edisla - 09-08-2015, 12:53 AM
RE: 41-280 Color Scheme - by klondike98 - 09-08-2015, 12:10 PM
RE: 41-280 Color Scheme - by Edisla - 09-08-2015, 05:08 PM
RE: 41-280 Color Scheme - by Fred Taylor - 09-11-2015, 10:00 AM
RE: 41-280 Color Scheme - by Edisla - 09-12-2015, 10:48 AM
RE: 41-280 Color Scheme - by Fred Taylor - 09-12-2015, 05:54 PM
RE: 41-280 Color Scheme - by Edisla - 09-13-2015, 01:13 AM
RE: 41-280 finish - by Fred Taylor - 04-26-2015, 11:21 PM
41-280 Color Scheme - by Edisla - 07-27-2015, 10:17 PM
RE: 41-280 Color Scheme - by Fred Taylor - 07-27-2015, 11:20 PM
RE: 41-280 Color Scheme - by Edisla - 08-01-2015, 10:28 PM
RE: 41-280 Color Scheme - by ccomer1955 - 09-02-2015, 10:36 PM
RE: 41-280 finish - by ccomer1955 - 09-02-2015, 10:39 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 3248 online users. [Complete List]
» 4 Member(s) | 3244 Guest(s)
AvatarAvatarAvatarAvatar
