FOMOCO Radio
Thanks. I didn't have an antenna attached when I tested it. All I got out of the speaker was a hum and the bulb didn't work. I tested the bulb separately and it does work. Guess the radio needs repair.
FOMOCO Radio - by unit91 - 09-08-2015, 02:14 PM
RE: FOMOCO Radio - by VntgRads - 09-08-2015, 05:07 PM
RE: FOMOCO Radio - by unit91 - 09-09-2015, 01:39 PM
RE: FOMOCO Radio - by VntgRads - 09-09-2015, 01:47 PM
RE: FOMOCO Radio - by klondike98 - 09-09-2015, 03:26 PM
RE: FOMOCO Radio - by unit91 - 09-09-2015, 07:39 PM
RE: FOMOCO Radio - by VntgRads - 09-09-2015, 08:55 PM
RE: FOMOCO Radio - by unit91 - 09-10-2015, 08:07 PM
RE: FOMOCO Radio - by VntgRads - 09-10-2015, 09:49 PM
RE: FOMOCO Radio - by unit91 - 09-11-2015, 01:40 PM
RE: FOMOCO Radio - by VntgRads - 09-11-2015, 07:14 PM
RE: FOMOCO Radio - by unit91 - 09-12-2015, 04:20 PM
RE: FOMOCO Radio - by unit91 - 09-14-2015, 01:23 PM
RE: FOMOCO Radio - by unit91 - 09-12-2015, 03:47 PM
RE: FOMOCO Radio - by VntgRads - 09-12-2015, 05:48 PM
RE: FOMOCO Radio - by VntgRads - 09-14-2015, 02:12 PM
RE: FOMOCO Radio - by unit91 - 09-14-2015, 04:44 PM
RE: FOMOCO Radio - by VntgRads - 09-14-2015, 06:44 PM
Eico 232 VTVM Schematic
There are currently 8998 online users. [Complete List]
» 1 Member(s) | 8997 Guest(s)
