My Museum Quality Philco Console 37-690 Radio
#35
Hope this time I uploaded the photos correctly.
Sam
RE: My Museum Quality Philco Console 38-690 Radio - by Sam samuelian - 09-11-2015, 06:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
