My Museum Quality Philco Console 37-690 Radio
#39
It's never too late to change the title of a thread. I've done it for you, along with making two slight corrections to the text in your initial post in this thread to make it all make sense.
For future reference:
If you start a thread and have a valid need to change the thread title later, all you have to do is:
1. Go to the first post in the thread.
2. Click the Edit button under that first post and then click Full Edit.
3. You will see a text box to the right of the word Subject with the title of the thread. Make your changes as needed.
4. Scroll down and click the Update Post button.
RE: My Museum Quality Philco Console 38-690 Radio - by Ron Ramirez - 09-12-2015, 11:12 AM
Users browsing this thread: 16 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
