Newbe Need Information regarding restoring a Philco Model 51
I would recommend 'The Elements of Radio Servicing' by Marcus and Levy. You can download it several chapters at a time here. http://www.antiqueradios.com/archive.shtml
Ed
Re: Newbe Need Information regarding restoring a Philco Model 51 - by etech - 03-02-2009, 06:52 PM
Philco 91 Tuning Condenser
There are currently 9861 online users. [Complete List]
» 1 Member(s) | 9860 Guest(s)
