It's been a while... FOUND
Since I've run across a problem like this. I have a 49-905 that I just finished replacing all the electrolytic and paper capacitors. All tubes and resistors check ok. My problem is a hum. It gets louder with the volume control but never over powers a station. I checked all the wires and they appear to be dressed as original. Even though the tubes tested good I swapped them out 1 by 1 with no difference.
Any help will be appreciated.
Schematic
Eric
The Villages, FL
It's been a while... FOUND - by Eric Adams - 09-12-2015, 11:22 PM
RE: It's been a while... - by morzh - 09-13-2015, 12:19 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:00 AM
RE: It's been a while... - by Radioroslyn - 09-13-2015, 08:35 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:58 PM
RE: It's been a while... FOUND - by Eric Adams - 10-03-2015, 05:07 PM
RE: It's been a while... FOUND - by klondike98 - 10-04-2015, 11:45 AM
There are currently 4914 online users. [Complete List]
» 1 Member(s) | 4913 Guest(s)
