It's been a while... FOUND
Eric
Hum can be anything.
Does it change with tuning or stays constant?
Now, often it is a result of bad ground. Look at rivets holding ground leaves where wire solder to. These are often the culprits.
It's been a while... FOUND - by Eric Adams - 09-12-2015, 11:22 PM
RE: It's been a while... - by morzh - 09-13-2015, 12:19 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:00 AM
RE: It's been a while... - by Radioroslyn - 09-13-2015, 08:35 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:58 PM
RE: It's been a while... FOUND - by Eric Adams - 10-03-2015, 05:07 PM
RE: It's been a while... FOUND - by klondike98 - 10-04-2015, 11:45 AM
There are currently 3397 online users. [Complete List]
» 3 Member(s) | 3394 Guest(s)
