It's been a while... FOUND
Thanks, Terry. Tube swap has been tried. I'm just going to check all the grounds and recheck all of my solder joints.
I'll let you guys know how it turns out.
Eric
The Villages, FL
It's been a while... FOUND - by Eric Adams - 09-12-2015, 11:22 PM
RE: It's been a while... - by morzh - 09-13-2015, 12:19 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:00 AM
RE: It's been a while... - by Radioroslyn - 09-13-2015, 08:35 AM
RE: It's been a while... - by Eric Adams - 09-13-2015, 01:58 PM
RE: It's been a while... FOUND - by Eric Adams - 10-03-2015, 05:07 PM
RE: It's been a while... FOUND - by klondike98 - 10-04-2015, 11:45 AM
There are currently 7020 online users. [Complete List]
» 1 Member(s) | 7019 Guest(s)
