Philco 16 Code 125 Cherry Red 80
While you have the chassis out, you should rebuild the Bakelite block capacitors. The procedure is not difficult, and a little work now will certainly prevent future problems; the originals are sure to be leaky.
Tim KA3JRT
Tim KA3JRT
Philco 16 Code 125 Cherry Red 80 - by NV3G - 02-20-2009, 04:29 PM
Re: Philco 16 Code 125 Cherry Red 80 - by exray - 02-20-2009, 10:42 PM
Re: Philco 16 Code 125 Cherry Red 80 - by NV3G - 03-02-2009, 02:03 PM
Re: Philco 16 Code 125 Cherry Red 80 - by Tim Tress - 03-03-2009, 10:20 AM
There are currently 10225 online users. [Complete List]
» 3 Member(s) | 10222 Guest(s)
