Wanting information
(09-14-2015, 07:05 PM)codefox1 Wrote:  Yes, do have tubes tested, but on vintage sets that have not been used in decades tubes are the least of your problems.  At very least the electrolytic capacitors in the power supply section are almost certainly bad, and should be replaced BEFORE you attempt to fire the set up with mains power.  Once you get a schematic, post a copy of it here and someone will help you identify these "must dos."
Thank you for that information. I am currently travelling and when I get home I will follow your suggestions. I would like to thank everyone on this site for the assistance.
Wanting information - by bluenosecamper - 09-10-2015, 12:35 PM
RE: Wanting information - by klondike98 - 09-10-2015, 02:17 PM
RE: Wanting information - by bluenosecamper - 09-10-2015, 03:28 PM
RE: Wanting information - by klondike98 - 09-10-2015, 03:39 PM
RE: Wanting information - by klondike98 - 09-10-2015, 06:53 PM
RE: Wanting information - by bluenosecamper - 09-11-2015, 03:31 PM
RE: Wanting information - by klondike98 - 09-11-2015, 03:34 PM
RE: Wanting information - by klondike98 - 09-11-2015, 05:25 PM
RE: Wanting information - by bluenosecamper - 09-11-2015, 06:54 PM
RE: Wanting information - by Ron Ramirez - 09-11-2015, 07:22 PM
RE: Wanting information - by bluenosecamper - 09-12-2015, 09:45 AM
RE: Wanting information - by codefox1 - 09-14-2015, 07:05 PM
RE: Wanting information - by bluenosecamper - 09-15-2015, 06:14 PM
RE: Wanting information - by radiohenry - 09-15-2015, 07:06 PM
RE: Wanting information - by radiohenry - 09-15-2015, 07:32 PM
RE: Wanting information - by bluenosecamper - 09-18-2015, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
