Is there a retro-fit for the M-4 magnetic cartridge?
I'm running out of options to either restore or replace the magnetic cartridge in my Philco 48-1270, M-4 record player.  West Tech does not rebuild them and his other lead had none.  Does anyone have an idea of a replacment / retro-fit for this tone arm.  Has anyone ever done it?  Help appreciated ASAP.
Is there a retro-fit for the M-4 magnetic cartridge? - by clockman1954 - 09-16-2015, 01:01 AM
There are currently 4475 online users. [Complete List]
» 2 Member(s) | 4473 Guest(s)
