40-180. Pushbuttons work, manual tuning doesn't !!!SOLVED!!
Yes, but when manual tuning is selected, the whole variable capacitor and associated coils and contact to them are suspect. If there is a short or open in the associated variable capacitor or coils, or fault in the switch, it will not work. Of course, it's usually the other way around, push buttons not working, variable OK, but this is what you appear to have.
RE: 40-180. Pushbuttons work, manual tuning doesn't - by codefox1 - 09-17-2015, 09:44 PM
