40-180. Pushbuttons work, manual tuning doesn't !!!SOLVED!!
What do you think if I run a jumper directly from the variable cap to the #6 (250pfd) on the RF tube. Then run another jumper from terminal 1 of the osc. coil to the det-osc tube. This would bypass all related switches and wiring, just in case there is an intermittant short/open, or in case I missed something?
RE: 40-180. Pushbuttons work, manual tuning doesn't - by Patrick - 09-17-2015, 10:42 PM
There are currently 3853 online users. [Complete List]
» 2 Member(s) | 3851 Guest(s)
