40-180. Pushbuttons work, manual tuning doesn't !!!SOLVED!!
SOLVED! The wire from pin 1 on the oscillator coil, through 29A to the pushbutton was in the proper place. However, the wire that went from the pushbutton to pin 5 of the 6J8 wasn't. Therefore, 29A and the coil were not conected to the tube.
RE: 40-180. Pushbuttons work, manual tuning doesn't !!!SOLVED!! - by Patrick - 09-18-2015, 07:31 PM
There are currently 4558 online users. [Complete List]
» 2 Member(s) | 4556 Guest(s)
