41-255 Output Transformer
Codefox, can you reverse the secondaries to correct this, or does it only have to do with the primaries being in phase?
John Honeycutt
41-255 Output Transformer - by Raleigh - 09-19-2015, 03:49 PM
RE: 41-255 Output Transformer - by OZ4 - 09-19-2015, 06:35 PM
RE: 41-255 Output Transformer - by klondike98 - 09-19-2015, 06:38 PM
RE: 41-255 Output Transformer - by OZ4 - 09-19-2015, 06:41 PM
RE: 41-255 Output Transformer - by OZ4 - 09-19-2015, 06:42 PM
RE: 41-255 Output Transformer - by Mondial - 09-19-2015, 06:47 PM
RE: 41-255 Output Transformer - by Raleigh - 09-19-2015, 11:33 PM
RE: 41-255 Output Transformer - by codefox1 - 09-20-2015, 05:25 PM
RE: 41-255 Output Transformer - by Raleigh - 09-20-2015, 05:42 PM
RE: 41-255 Output Transformer - by codefox1 - 09-20-2015, 06:29 PM
RE: 41-255 Output Transformer - by Raleigh - 09-20-2015, 06:33 PM
RE: 41-255 Output Transformer - by codefox1 - 09-20-2015, 10:22 PM
RE: 41-255 Output Transformer - by Radioroslyn - 09-21-2015, 09:11 AM
RE: 41-255 Output Transformer - by Raleigh - 09-21-2015, 09:59 AM
