Philco Model 20 Grand Cathedral
(09-20-2015, 08:58 PM)morzh Wrote:  Where do we have any attached schematics?
On the Early set sch on this website is #14, 0.5uF.
Sorry.  I guess I haven't quite figured out how to attach a file.  However, thanks for pointing out the capacitor in question.  The newer model 20 schematic shows #14 as a .25uf and that is what I installed in the aluminum can.  I have both the early version and the newer version schematics.  I am assuming from Ron Ramirez' Philco Radio book that the model I have with the maple curly front is a later 1930 model.  The tuner in mine is a three gang tuning condenser.  Am I correct that the trimmer capacitors noted on the early schematic is the tuning capacitor?  If I am incorrect, maybe changing the .25uf to a 0.5uf may help?
Thanks for your patience and assistance.
Jay
Philco Model 20 Grand Cathedral - by Jay Thomas - 09-19-2015, 07:01 PM
RE: Philco Model 20 Grand Cathedral - by Mondial - 09-19-2015, 08:44 PM
RE: Philco Model 20 Grand Cathedral - by morzh - 09-20-2015, 12:07 AM
RE: Philco Model 20 Grand Cathedral - by Arran - 09-20-2015, 12:25 AM
RE: Philco Model 20 Grand Cathedral - by morzh - 09-20-2015, 08:58 PM
RE: Philco Model 20 Grand Cathedral - by Jay Thomas - 09-21-2015, 01:38 AM
